Basically my engine shit it self today as test and tune and I need pistons now for my gt and I'm wondering if the Glanza V pistons will fit a gt engine? So if you could let me know that would be cool thanks :)
standard pistons are numberd for size, so if your nakerd pistons have say number two on, then you need a number two replacement..
best bet is to forge it now mate, and drop another lump in whilst you forge..
what happened at test and tune? I didn't go as too tired after japfest..
Can't afford to forge it dude :/ my mate just stripped his Glanza and said I could use the pistons till I can afford to forge it :/ haha and not much really there was a lot of civics and American muscle cars lol I did a 15.8 flat which I thought not to bad for my 1st time and its basically standard lol
You could opt to use 4x size 3 marked pistons ( 73.93mm) And get the bores honed, although if anything happens to the cylinders again, you will need to go oversize as this is the largest OEM piston.
Or vice versa if you have marked 1 piston, use mark 2.
