had the fault code come up for temp sensor assumed the sensor it self so gone to fit a replacement and the plugs dropped of with corroded wiring,
it only had 1 wire going to it but 2 terminals so can anybody tell me where they both go to and which colour wire does what side :)
much appreciated
The brown wire is the ground on the ecu side, and the green/black wire goes to the ecu also, this would be the signal wire :)
Edited by AdamB
If looking at the plug with the rectangle plastic notch at the top, the connections at the bottom :
The left one goes to the Ground - ECU, the right connection goes to the ECU signal wire.
