Does anyone khow what rpm gauge and were i wire it on a P reg starlet sportif how to wire it up links will help alot thanks Gaz
The stock counter gets its signal from the dizzy trigger. Can't think of what one it is off the top of my head but can find out tomorrow.
That would be a massive help i have spent a day looking but carnt find anythink thank
Assuming you are trying to fit an aftermarket rev counter, the OEM counter picks up the signal from the ignitor then into the diagnostic box. The wire your looking for here is labelled IG - (minus), which has a white coloured wire at the dash end.
Hope that helps :)
