Licari3 Posted May 25, 2013 Posted May 25, 2013 Would i get a big difference in performance by replacing the stock ignition coil with an aftermarket one on a glanza ? Quote
Broony Posted May 25, 2013 Posted May 25, 2013 just doing that alone? then no, if its because your setup warrents it then it enable you turn run more boost , see sock's build thread for info Quote
AdamB Posted May 25, 2013 Posted May 25, 2013 Changing to wasted spark/sequential ignition will pose smoother running, better fuel economy, more torque. However you will need a standalone ecu to control them. You can upgrade the stock coil to an MSD item but it still uses the dizzy so has no benefits. Quote
