My engine is not far away from completion people who have been following my build can see bottom end is build up and head work is near finished and would like some advise on what sort of C/R would you advise me to run?
thoughts were to use a Athena 1.4 head gasket but its in question at the moment.
as want it to be reliable but still spool up and be responsive?
looking to run 1.5-1.6 bar full boost
car is intended for fast road and doing a fair few track days and looking to enter Toyota sprint series
basic spec list
Engine
4E-FTE Block
Wossner 74.5mm pistons
PEC rods
ACL main bearing
ACL big end bearings
ACL thrust bearings
ARP head bolts
ARP main stud and nut kit
Toyota oil pump
Toyota water pump
Toyota full gasket set
Toyota dizzy cap & rotor
NGK iridium spark plug
Magnacore 8mm HT Leads
Light weight crank pully
Light weight power steering pully
Head and inlet
Attain Throttle Pulley
Standard Inlet manifold ported to match head
Ported and polished head
3 angle valve job
PEC 1mm oversize big valve conversion
Toyota Yaris 1nzfe solid buckets
standard springs
standard cams
Fuel system
HKS highflow fuel rail
Sard fuel pressure regulator
Sard 550cc injectors
Turbo setup
Greddy TD05 16G turbo
Tial MVS 38mm vband wastegate
Race-Tech custom manifold
engine management
Power FC
any advise would be great
Edited by abbott
750cc injectors will be needed for anything above 1.5 bar
If you want good idle go for id1000
Like said that turbo spools super fast so concentrate on reliability 8.2 - 8.5/1 cr would be just right
Thanks again Gee all has been stored in my head to feed back to Rob. you have PM on FB
