abbott Posted May 30, 2013 Share Posted May 30, 2013 (edited) My engine is not far away from completion people who have been following my build can see bottom end is build up and head work is near finished and would like some advise on what sort of C/R would you advise me to run? thoughts were to use a Athena 1.4 head gasket but its in question at the moment. as want it to be reliable but still spool up and be responsive? looking to run 1.5-1.6 bar full boostcar is intended for fast road and doing a fair few track days and looking to enter Toyota sprint series basic spec list Engine4E-FTE BlockWossner 74.5mm pistonsPEC rodsACL main bearingACL big end bearingsACL thrust bearingsARP head boltsARP main stud and nut kitToyota oil pumpToyota water pumpToyota full gasket setToyota dizzy cap & rotorNGK iridium spark plugMagnacore 8mm HT LeadsLight weight crank pullyLight weight power steering pully Head and inletAttain Throttle PulleyStandard Inlet manifold ported to match headPorted and polished head3 angle valve jobPEC 1mm oversize big valve conversionToyota Yaris 1nzfe solid bucketsstandard springsstandard cams Fuel systemHKS highflow fuel railSard fuel pressure regulatorSard 550cc injectors Turbo setupGreddy TD05 16G turboTial MVS 38mm vband wastegateRace-Tech custom manifold engine management Power FC any advise would be great Edited May 30, 2013 by abbott Quote Link to post Share on other sites
glanzagee Posted May 30, 2013 Share Posted May 30, 2013 750cc injectors will be needed for anything above 1.5 barIf you want good idle go for id1000Like said that turbo spools super fast so concentrate on reliability 8.2 - 8.5/1 cr would be just right Quote Link to post Share on other sites
abbott Posted May 30, 2013 Author Share Posted May 30, 2013 750cc injectors will be needed for anything above 1.5 barIf you want good idle go for id1000Like said that turbo spools super fast so concentrate on reliability 8.2 - 8.5/1 cr would be just rightThanks again Gee all has been stored in my head to feed back to Rob. you have PM on FB Quote Link to post Share on other sites
