Chrishoughton1989 Posted May 30, 2013 Posted May 30, 2013 What's the best way to remove ? Head is off the engine :/ thanks. Quote
AdamB Posted May 30, 2013 Posted May 30, 2013 Usea pulley puller. Seen way too many smacked with a hammer, crowbar and whatever else and you end up with a chipped or cracked pulley thats good for the bin. Quote
Chrishoughton1989 Posted May 30, 2013 Author Posted May 30, 2013 Cheers and how about to undo the bolt ? Car got no compression to help as heads off. Lol Quote
AdamB Posted May 30, 2013 Posted May 30, 2013 Easiest way is to use an impact gun, failing that jam the flywheel with a strong screwdriver/crowbar, get a long breaker bar and give it a tug. Some people put the breaker bar on and crank the engine over, but wouldn't recommend it as if the socket isn't on properly you'll easily round it off. Quote
Chrishoughton1989 Posted May 30, 2013 Author Posted May 30, 2013 Thank you. I would be lost without this forum ha ha. Quote
