Billy SR Posted June 10, 2013 Posted June 10, 2013 This happened with my old sr but I never managed to sort it as I had an accident a few days later. One of my brake lights has gone out, but upon changing the bulb it is just causing all 3 lights to get stuck when i turn main beam on. I take the bulb out and I'm back to normal again. Is it the bulb that is causing this short circuit? :/ simple little problem but a pain in the arse Quote
Danza V Posted June 10, 2013 Posted June 10, 2013 Wrong bulb probably.. Check it's only got two pin/knubs on the bottom of the bulb. I had this issue Quote
Billy SR Posted June 10, 2013 Author Posted June 10, 2013 Tried some different bulbs that I tried to put in before but didn't wanna force, turns out they just clicked in place eventually. Was down to wrong bulbs as these had the correct voltage, cheers guys Quote
