Don't no if I'm explaining this right but basically I was fiddling with my intercooler kit last night when I noticed the bolts on the flange for the hot side pipe had worked there way loose and I tightened the bolt and one of them cross threaded I got it out in the end it's a long threaded bolt one side threads into the turbo and the other side you thread the nut onto anyone No where I can get a replacement for this or what the size measurements of this bolt are got a major boost leak going on as we'll since this so I'm guessing its leaking boost out of the flange :(
Any info much appreciated
Thanks
Cheers mate ill go up there just getting the time to get there from work not something I can just buy from a DIY motor shop ?
