mattglanza79 Posted June 24, 2013 Posted June 24, 2013 HiMy glanza is pushing 0.9 bar of boost on ct9 plus standard intercooler is this safe ? How can I wind back to 0.8 on a hks adjustable actuator if not. Help please peeps . Quote
StuDoc 72 Posted June 24, 2013 Posted June 24, 2013 Not if you have standard ecu aswell. Arent you hitting fuel cut? Just loosen off the locking nut on the actuator arm then make the arm slightly longer. This will turn down the boost. Quote
AlancEP82 Posted June 24, 2013 Posted June 24, 2013 lengthen the the wee bar one on the acuater half turn at a time and keep an eye on your boost gauge Quote
mattglanza79 Posted June 24, 2013 Author Posted June 24, 2013 Cheers boys. Never hit fuel cut. Must have fcd somewhere. Bloody car. One thing after another Quote
mattglanza79 Posted June 24, 2013 Author Posted June 24, 2013 So that would be turning it anti clockwise ? Quote
AlancEP82 Posted June 24, 2013 Posted June 24, 2013 check around the ecu for a fuel cut defender,could have differint ecu either Quote
