Chrishoughton1989 Posted June 24, 2013 Posted June 24, 2013 What springs will I need? Thanks. 38mm thanks. Quote
Chrishoughton1989 Posted June 24, 2013 Author Posted June 24, 2013 Thanks. Now I'm being dumb. How do I no what colomb to use lol. Quote
yaristurbo Posted June 24, 2013 Posted June 24, 2013 How new is the wastegate, the colours are completely different if you bought new have a scan through all the sprigs and see which coloum they match up with Quote
Chrishoughton1989 Posted June 24, 2013 Author Posted June 24, 2013 It's fairly new. Water cooled ? Quote
yaristurbo Posted June 24, 2013 Posted June 24, 2013 38mm will be mvs did you but it new?The colours are sprayed on the springsThink both are water cooled now Quote
Chrishoughton1989 Posted June 24, 2013 Author Posted June 24, 2013 Yes bought new. So will I need grey and gold? or black and red? To run a bar ? Quote
DevonGT Posted June 24, 2013 Posted June 24, 2013 Are you planning on running just 1bar of boost? Quote
DevonGT Posted June 24, 2013 Posted June 24, 2013 If your not planning on going any higher in the near future and you bought the wastegate recently, I would go with a black spring. Quote
DevonGT Posted June 24, 2013 Posted June 24, 2013 (edited) Just black. With that you'll be able run 1bar and have a lower setting of 0.6bar if you wanted to. If you have an EBC. Edited June 24, 2013 by DevonGT Quote
Chrishoughton1989 Posted June 24, 2013 Author Posted June 24, 2013 I don't. Just going to use one spring and run a bar ? Quote
DevonGT Posted June 24, 2013 Posted June 24, 2013 (edited) Black will be ok then. You don't need to run a 1bar spring to run 1bar of boost. If you don't have an EBC, black+red. Edited June 24, 2013 by DevonGT Quote
