macgregor38 Posted June 24, 2013 Posted June 24, 2013 got a abs fault and need the sensor wire colours or even a list of the ecu plug pins to test them individually please, thanks Quote
macgregor38 Posted June 24, 2013 Author Posted June 24, 2013 http://i231.photobucket.com/albums/ee100/texx10/sensorwiringdiagram.png got blink codes 32 33 and 47all sensors checked out fine after a clean up and reset however 47 stayed found this to be the brake pedal sensorsorted Quote
macgregor38 Posted June 24, 2013 Author Posted June 24, 2013 ABS diagnostic:Turn on ignitionLink out Tc and E1 in the diagnostic plug.Read the warning light flashes like the ecu.Codes11 Open circuit in solenoid relay12 Short circuit in solenoid relay13 Open circuit in pump motor relay circuit14 Short circuit in pump motor relay circuit21 Open or short circuit in 2 position solenoid of front right wheel22 Open or short circuit in 2 position solenoid of front left wheel23 Open or short circuit in 2 position solenoid of rear right wheel24 Open or short circuit in 2 position solenoid of rear left wheel31 Right front wheel sensor signal malfunction32 Left front wheel sensor signal malfunction33 Right rear wheel sensor signal malfunction34 Left rear wheel sensor signal malfunction41 Abnormally high or low battery voltage51 Actuator pump motor locked or open circuit in pump motorAlways on ABS ecu malfunctionReset by pumping the brake pedal 8 times or more in 3 seconds with the link in or remove ECU-B fuse.http://i141.photobucket.com/albums/r62/fishman_photos/GT/glanzaecu.jpg Quote
