Picked my white gt turbo up today had a little drive in the port and it seems to be stuttering a bit dont know maybe bacause it hasnt being run in yet after its long trip. It also has a blitz boost gauge installed and on the clocks its reading -1 on idle and on the blitz its reading far below zero. Any help is much appreciated.
Hi mate
Its more likely to do with your ignition ...
Ditch your distributor cap and rotor these are cheap items and put new plugs in NGK 8 or 7 check also your leads (these are the dearest part) a lot of starlets are very tempramental with their sparks thats why you see a lot of them with full engine bay earthing kits ......
Thanks for the advice i got it sorted at the weekend i changed all the plugs as the salt water had got into them so it wasnt fireing on all cylinders. Thanks anyway guys :unsure:
