Make sure you get the right one, I fitted mine the other day and they only come on with full lights on and go off when full beam is on!
Use the source from the sidelights so that they come on when they should. Failing that you could jus use an ignition live.
I accidentally used the right indicator earth was quite funny they would come on with the side lights perfectly but when you indicated right they would flash lol.
Edited by StuDoc 72
