Pierros Posted July 1, 2013 Posted July 1, 2013 Hello Does anybody know injector lag time (also called injector dead time) of the OE fuel injectors of 1gen Cynos 5E-FHE (225cc, part number 23250-1107) ??? Quote
AdamB Posted July 1, 2013 Posted July 1, 2013 You can test it using an oscilloscope to find the dead time. I doubt Toyota would release such information tbh. Quote
Pierros Posted July 1, 2013 Author Posted July 1, 2013 Thanks for the reply. If I'm not able to find them, I'll just have to switch them with the 295cc 4E-FTE (that I have the correct lag time) and re-tune my ECU. Quote
AdamB Posted July 1, 2013 Posted July 1, 2013 You would be better using the 4EFTE 295cc injectors anyway. Whats the need to switch to a lower rate injector? Quote
Pierros Posted July 2, 2013 Author Posted July 2, 2013 (edited) I'm running an N/A 5e-fhe with ACIS to my paseo, so its the OE injectors. When I made the conversion I was planning to boost it, so I used a Glanza loom and I'm running a Power FC, but since then some things changed and haven't boost it yet. The problem is that the car is not performing as it should be and this must be due to the wrong lag time of the injectors (as I have checked everything else). Edited July 2, 2013 by Pierros Quote
