so about to order these wiseco pistons through a guy from a tuning company guy, hes getting them from the states but can either get the 8.5:1 or 9:1, would i be better off with the higher or lower compression? i was thinking lower but gimme your opinions!!
From alamo? They are custom specced pistons etc. I went for 9.1 just trying to work out how i can lower it just a tad to make it more reliable
Higher comp is better if you can keep det at bay which should be fine on 99 ron fuel
What ecu, fuel and boost do you plan on running? Ulitmately these will affect what your static CR can be.
Is it 5E or 4E?
The higher the better, greater fuel economy, more power, more torque, linear powerband etc, however as said you'll increase the chances of knock and you'll also need a very good ignition system to provide a strong spark under high pressures.
Edited by AdamB
running stock ecu and turbo, on 0.8 - 1 bar on 4e lump, i have a 255 fuel pump, fpr etc I was going to stick it straight on the dyno once its rebuilt to give it a proper fuel tune, sound appropriate? whats your opinions on the spec that im running @AdamB
My opinion would be it seem's like a bit of a waste of money to spend running a standard turbo and ecu really. You can run that boost pressure all day on a standard engine. Unless your looking to run some power later on?
whats a waste of money? in 6months or so i do plan on running bigger power, only reason im going forged is cause i have no choice as 3 of my pistons went remember :(
Ah yeah fair enough.
Well how much power do you want to run in the future? I'd be looking to run a CR of around 8.5:1 for most setups.
