Is it possible to have my standard ep82 ecu remapped to run a td04 instead of emanage ect?
And would i still need my fpr and fcd?
Edited by Sandham
the standard ECU cannot be remapped, you need some form of piggyback like emanage or a standalone ecu like OMEX to get a proper "mapped" setup.
but many people run the td04 using an fcd and fpr, including myself (technically i use a fuel controller, which is just a fancy fcd really)
to do it properly you would want the fueling set up on a rolling road with some way of detecting detonation (det cans), and a wideband for measuring the afr
