sayer88 Posted August 18, 2013 Share Posted August 18, 2013 Hi everybody, slight issue with glanza this morning. Got up lifted bonnet to do general checks before a long motorway drive all fine, started up fine drove about a mile down the road stopped at traffic lights pulled away and she started stuttering pulled over and she idled fine so drove off got about 100yrds further Then started again pulled over again this time she cut out. Turned key took about 8-10seconds to actually start up which it's never done before drove it home ok switched her off turbo timer kicked in and she ticked over perfectly fine. My only thought is when I lifted the bonnet a fair bit of water ran into the back of the engine bay maybe the water was shorting something out. Any advise and help would be great thanks. Dan Quote Link to post Share on other sites
AdamB Posted August 18, 2013 Share Posted August 18, 2013 Try the spark plug holes mate. Spray some WD40 down there. Quote Link to post Share on other sites
sayer88 Posted August 19, 2013 Author Share Posted August 19, 2013 Thanks mate shall give that a go later. Quote Link to post Share on other sites
Mikeyallgood85 Posted August 19, 2013 Share Posted August 19, 2013 Check your battery terminals they could be lose had this problem on my old evo witch would make it cut out! boost leak could also do the same! ;-) Quote Link to post Share on other sites
Weyro Posted August 19, 2013 Share Posted August 19, 2013 take the dizzy cap off and clean up all the contacts with wd40 Quote Link to post Share on other sites
sayer88 Posted August 20, 2013 Author Share Posted August 20, 2013 Thanks lads will keep you informed when I solve the issue Quote Link to post Share on other sites
