Right where do I start
After some advice guys + girls
I've got a Glanza that I use as a track car and its taking a fair bit of abuse
But what the problem is I had a track day on Monday this week and lasted most of the day until it started to really struggle to get into any gears
So I managed to get it home and started to strip it down
As in my head I thought clutch
Was running a excedy stage 2 paddle clutch which has done the trick for 2 years can't complain
Anyways I stripped the box off on Monday and had already ordered a new competition spec clutch from race tech
And while it was off bought and also fitted a slave cylinder and fitted some new up rated gear selector bushes
But managed to get it put all back together yesterday and had to leave it
But had a had off work and this minding being bleeding it all back up and checking everything and its still exactly the same :/
Next thing I can think of doing is changing the master cylinder and possibly the release fork
Has anyone has this problem before? Or does anyone think its the gearbox that's the problem but I was more towards the clutch as its every gear not just one maybe two
Thanks
Chand
When you say struggle to get gears, do you mean it grinds? It's stiff?
Have you checked to make sure you are getting the clutch fully engaged/disengaged when the pedal is pressed?
Grinds into third mainly and doesn't a really want to go into first or fourth half the time
Like have pump the clutch a fair few times to get it in
And then I have to really push it into them :/
Yes mate clutch is moving correctly as its moving the slave cylinder fully etc
Yeah I'd probably be inclined to say you've got a synchro problem. Probably worth doing a complete overhaul replacing the forks, synchro rings, bearings and any gears that are chewed up.
I was swayed away from a synco problem as its not just one gear rare to see a problem with like 4 gears that was all
But thanks for advice il change the master cylinder when it turns up and then see how it is if not I will look at reconditioning the gear box
Thanks again
Clutch mast cylinder turned up today
Got it fitted and drained oil out and put fresh new stuff in and fully bleed system back up and seems to have done the trick fingers crossed
Still struggles to get into first but does go in after a few pumps
So gunna adjust biting point and bleed it up once again to make sure but hopefully it's cured the problem
Sounds good mate! I doubt you'll ever get the box 100% as they are getting old and tired now, after racing them as well it doesn't do them any favours. Change the oil as regular as possible reeally to keep it healthy.
It's only on rare occasions that I've heard of more than one gear synco go what makes you so sure it's that
That's the problem please?
As I've fitted the master cylinder and bleed it up again and still not much change :/
But now when it's in neutral when I put down on clutch all the way and slowly bring it back up its like feeling like its got a bite on a gear and once earlier while trying it
It was in neutral did the same and bit but then once got past the bitting point it stalled :/
Just really confusing me as never had problem like this before
Also I've noticed the little black rubber for gear selectors (sugar cube) is worn can these be purchased anywhere?
Thanks
Normally if the selector forks are shot, it pops out of gear, I've seen some cases where you actually have to hold it in gear it can get that bad.
A synchro will grind, or not allow the correctly match engine speed to allow you to select the gear.
Have you checked the cables? The sugar cube may well be a problem that certainly isn't helping. Am not sure if you can buy them new anywhere, best place would either be Iddy or Toyota.
So do you think with the reason is why the car is like its still in gear more like the gear box? Like the gear selector internally it something?
I would look to change the sugar cube first as its the cheaper option, you say your one looks worn anyway, so replacing it isn't going to do any harm.
Yeah it's definatly got movement in it as I've got uprated gear bushes and pilot bush mounts and gear stick still moves when I move etc so that wouldn't help with the problem
Not clutch mate its a gear has welded it it self to the input shaft by the looks of it :/
Taken it to a local transmission company
