bigash86 Posted August 25, 2013 Posted August 25, 2013 Hi just wondering if anyone has any experience with these rods and how they have been rated there is a forged package on sale ebay which I thought was reasonable price spec as followsStarlet 1300 turbo Ultimate engine rebuild kit This kit includes,Wossner forged piston set (rings,pins and clips included) available in 74mm 74.5mm and 75mm bore sizes (please state when ordering)ZRP forged connecting rod set fitted with ARP 2000 fasteners and rated to over 600 bhp on 4 cylinder engines.Athena MLS steel headgasket available in 1.2mm or 1.4mm (please state when ordering)ACL main bearing set and thrust washer set at std sizeCalico coated ACL big end bearing set (these are the ultimate performance bearings with high lubrication coating for extreme performance) For any info required you can contact us on 01278 453036 Quote
bigash86 Posted August 25, 2013 Author Posted August 25, 2013 £1050 delivered however he may do it a little cheaper as its on eBay I don't know pretty good I thought Quote
AdamB Posted August 25, 2013 Posted August 25, 2013 The ZRP con rods are a sub-division os Wossner I believe, much like PEC, so quality should be pretty good. I'm not the biggest fan of Wossner pistons though, but there's too much detail to go into for this thread as its down to the piston design. Quote
