Ok so i bought my glanza as a rolling shell and got an engine for it lastnite
Most things were straight forward but ive a few wires that i cant find anywere for them to plug in to
They seem to sit above the gearbox and one also comes from the same loom as the plug from the dizzy cap
around that area is
reverse light switch directly on top of gear box
numerous water temp sensors on thermostat housing is bottom hose goes on there
oil pressure switch is on the part of the loom front behind downpipe
the gear box looks to be plugged in
but the green on looks to be water temp maybe the one facing bulk head on thermo hosuing
hope this helps
See tbh i cant find anywere for them to plug in lol ive looked and looked so i just left it so it dosnt fry my head lol
Fresh eyes in the morning mite help
green one is for coolant temp sensor, the 2 gray ones is for your lambda sensor and cat temp sensor and the gray one on its own, im not sure, looks like the idle control valve plug but the icv is on the other side of the engine bay
