brendonware Posted September 16, 2013 Posted September 16, 2013 Everytime when i drive my car the revs seems to hang around random numbers. For instence i will be driving and when i put the clutch in or put it in neutral the revs will just go up to like 3,000, it seems if i give it a bit of a rag up the rev range it will drop past the sticking point and usually drop back down to what it should be. It sticks anywhere really, from like 1,500 - 3,500, but it revs normally, i still have all the response as normal on the throttle.Was thinking it is probably my throttle cable sticking? Any help is appreciated. Thanks,Brendon Quote
yaristurbo Posted September 16, 2013 Posted September 16, 2013 A wiring plug used to get stuck behind my pedal had to switch it off everytime Quote
brendonware Posted September 19, 2013 Author Posted September 19, 2013 Thanks I'll take a look. Any other suggestions? Quote
drako Posted September 22, 2013 Posted September 22, 2013 Did you sort this dude? Got similar problems with me.. revs go crazy and if i dip the clutch they die and return back to normal for a few seconds and hit the roof again :/ its also very jerky in over run and low so again i got to dip the clutch to make it die down. I've changed the ICV, Cold start valve and throttle position sensor yet problem is still there. Quote
brendonware Posted October 2, 2013 Author Posted October 2, 2013 nah mine is still playing up :/ spoke to a mate at work and he suggested cleaning my ICV as i was edging towards it being a sticky cable. But if you say you have changed all of that then my advice isnt of any help Is the ICV easy to get at and clean? ThanksBrendon Quote
drako Posted October 12, 2013 Posted October 12, 2013 Ahhh balls!! I cleaned my ICV out but no good for me. I've gone down the extent of buying a new fmic now as mines bashed about so not sure it's it's leaking. The ICV is easy to get to and clean. It's right on the end of the inlet left side. Held in by two small 10mm bolts and some earth leads attatched the right side bolt. Take it off and pry the tabs over a little and remove the insides. Be carful it doesn't all fall out when your doing it. Quote
brendonware Posted October 16, 2013 Author Posted October 16, 2013 Thanks mate, cleaned the ICV and cleaned inside the throttle body with carb cleaner and fingerscrossed it hasnt done it since! going up to tuning developments tomorrow so my car is almost finished Quote
Turk Posted November 3, 2013 Posted November 3, 2013 Drako you might want to try your temp sensor. But check for any leaks first. Seems like a sticky throttle if you ask me. Or it could also be an earthing problem. Theres also a guide somewhere on how to calibrate your tps. It might not be calibrated. Just things to check out for.good luck anyway Quote
