hi
i have install a turbo kit from corona diesel
the rear part is the same with the ct9 but
the bottom is bigger!
i have destroy 3 oem manifolds and one aftermarket,so
i wonder if i buy a zisco one (370gpb) if it works until 3000rpm
with an oem ecu at 1.0 bar with hks actuator?
the car has downpipe 63mm and the 55mm exhaust.
if anyone knows or has try a same setup please inform me
thanks
efklidis
Efklidis,
If this is being fitted on a diesel, then please do inform us as it will require extra bracing.
Otherwise it will be fine.
I replied to your email the other day, if you have any other queries do not hesitate to ask.
Keith
ZiscoPerformance
It's on 4e fte engine
i'm asking cause two friends of mine fitted a not oem mani on a ct9 with longer routes and the had problem until 3000rpm
with aftermarket ecu
