Hi never had a standard car and it seams like only starts to pull hard at 4k+
What is the basic standard boost setting and when are you hitting it
Gauge will show .4 at around 2.5k bit as said will only pull hard s 4k, boost staying the same
Is this normal?
Still using the stock actuator? Most probably that that's making boost lazy allowing the wastegate to open early than it should.
Stock actuator. And restricted I believe
that's your prob mate, worn out spring in the actuator wont let it hold boost.
theres a hks actuator for sale at the minute on tggt.. though im sure you can get one handy here if you put up a wanted thread
