Hello,
I bought Starlet N/A. Got problems after I changed engine. When I turn key to ignition, there is no check engine light. And when i try to start engine, there is no spark and seems fuel pump doesn't work. Than I removed aftermarket alarm, but that not helps...
I think there is problem with immobiliser, so how to remove/disconnect/disable immobiliser?
Edited by Anglas
