dinbird Posted November 6, 2013 Posted November 6, 2013 why my gearbox oil came out (overflow) from speedo cable end (connected with gearbox) need you guide and assistance to fix this problem, i already tightened the cable. but still the oil overflow. need your guide and help to fix this problem.thanks. Quote
yaristurbo Posted November 6, 2013 Posted November 6, 2013 Was the car on level ground? Think there's a o ring on speedo drive if that's where it's leaking fromMine only did this when front jacked up Quote
dinbird Posted November 6, 2013 Author Posted November 6, 2013 yeah on the ground mate. the leaking came out from the area of speedo meter end (i suspected). really wonder why. Fyi, i just fitted a new Kaaz LSD Into my non LSD box.Did i over filled the oil? i filled roughly about 2 litre... Quote
yaristurbo Posted November 6, 2013 Posted November 6, 2013 The level bung is at the front level ground and fill till runs out.Get it on level ground take out the bung at the front of box 24mm and see if any excess comes out and report back budClean it down as well and recheck leak Quote
