I have recently just fitted a vf24 rollerbearing turbo with external wastgate how should the boost hoses be set up? I have 2 ports on the external wastgate and obv one on the compressor housing. I have a gizzmo boost ebc fitter aswell so was wondering the best way to plumb the boost hoses in. As i have no control over the boost
Still not really understanding that . I dont no if the bottom port on the wastgate has to pipes to the compressor housing and bleed to the boost controller and the top port on the wastegate run straight to the second port on the boost controller? Can anyone help?
This doesn't make sense.
post pics
Ok that helps just dont no where the boost controller fits in
do you mean inside car?
Looks like both ports goin to the compressor housing
Vac pipe off turbo splits into 2 vac pipes 1 goes to bottom wastegate port and the other goes to boost controller solenoid then to top port on wastegate.
If this still doesn't help take it to sum one that knows what their doing.
