renfrewshiremod_craig Posted November 10, 2013 Share Posted November 10, 2013 I have recently just fitted a vf24 rollerbearing turbo with external wastgate how should the boost hoses be set up? I have 2 ports on the external wastgate and obv one on the compressor housing. I have a gizzmo boost ebc fitter aswell so was wondering the best way to plumb the boost hoses in. As i have no control over the boost Quote Link to post Share on other sites
Mad Mike EP82 Posted November 10, 2013 Share Posted November 10, 2013 There's a diagram on this page http://www.lancerregister.com/showthread.php?t=231510&page=3 Quote Link to post Share on other sites
renfrewshiremod_craig Posted November 10, 2013 Author Share Posted November 10, 2013 Still not really understanding that . I dont no if the bottom port on the wastgate has to pipes to the compressor housing and bleed to the boost controller and the top port on the wastegate run straight to the second port on the boost controller? Can anyone help? Still not really understanding that . I dont no if the bottom port on the wastgate has to pipes to the compressor housing and bleed to the boost controller and the top port on the wastegate run straight to the second port on the boost controller? Can anyone help? Quote Link to post Share on other sites
Mad Mike EP82 Posted November 10, 2013 Share Posted November 10, 2013 On 11/10/2013 at 7:27 PM, renfrewshiremod_craig said: Still not really understanding that . I dont no if the bottom port on the wastgate has to pipes to the compressor housing and bleed to the boost controller and the top port on the wastegate run straight to the second port on the boost controller? Can anyone help?Still not really understanding that . I dont no if the bottom port on the wastgate has to pipes to the compressor housing and bleed to the boost controller and the top port on the wastegate run straight to the second port on the boost controller? Can anyone help? This doesn't make sense. post pics Quote Link to post Share on other sites
renfrewshiremod_craig Posted November 10, 2013 Author Share Posted November 10, 2013 I dont no how to post pictures on here. Well on the tial external wastgate there is 2 ports one on the bottom and one on the top. And there is one port on ther compressor housing. What boost ports get connected where? Quote Link to post Share on other sites
Mad Mike EP82 Posted November 10, 2013 Share Posted November 10, 2013 This might help. Quote Link to post Share on other sites
renfrewshiremod_craig Posted November 10, 2013 Author Share Posted November 10, 2013 Looks like both ports goin to the compressor housing Looks like both ports goin to the compressor housing Quote Link to post Share on other sites
EP-Azz Posted November 11, 2013 Share Posted November 11, 2013 That's how it's normally set up , Quote Link to post Share on other sites
renfrewshiremod_craig Posted November 11, 2013 Author Share Posted November 11, 2013 Ok that helps just dont no where the boost controller fits in Quote Link to post Share on other sites
Mad Mike EP82 Posted November 11, 2013 Share Posted November 11, 2013 On 11/11/2013 at 3:19 AM, renfrewshiremod_craig said: Ok that helps just dont no where the boost controller fits indo you mean inside car? On 11/10/2013 at 9:47 PM, renfrewshiremod_craig said: Looks like both ports goin to the compressor housingLooks like both ports goin to the compressor housing Vac pipe off turbo splits into 2 vac pipes 1 goes to bottom wastegate port and the other goes to boost controller solenoid then to top port on wastegate. If this still doesn't help take it to sum one that knows what their doing. Quote Link to post Share on other sites
renfrewshiremod_craig Posted November 11, 2013 Author Share Posted November 11, 2013 Ok i think i made the mistake of connectin the split to the bottom of the wastegate port instead of the top. Quote Link to post Share on other sites
