Dusty Posted November 15, 2013 Posted November 15, 2013 Hi Not long ago I bought myself my first v just starting to do my own few touches , these two gauges were at the bottom of the centre console below the radio and there was a head unit with a big gapin hole so I decided to swap them around as the gauges were on a carbon fibre sheet with a block of wood behind it which fitted in the bigger gap where the CD player was and stuck it in with some glue and I thought job well done, went a run and temp went to 150 and the pressure wasn't reading anything, is there any guides or how 2''s on how to wire these up so I can go over it and make sure everything's as it should be also what should the pressure be? It's currently got full decat aftermarket exhaust standerd manifold and standerd ecu blitz rad relocated air filter and HKS actuator Cheers guys any help appreciated Dusty Quote
DaddyDutch Posted November 16, 2013 Posted November 16, 2013 Some pics might help on this one mate. Al Quote
Dusty Posted November 16, 2013 Author Posted November 16, 2013 Ok mate is photo bucket the only option to post pics? If so I'll need to create an account and get sum pics up not in real rush as they still light up and look the part will get sum pics up after I've created an account see if anyone can see where I've went wrong might just be loose wire but a guide or wiring gram would be good so I can compare to mine Cheers dusty Quote
Broony Posted November 16, 2013 Posted November 16, 2013 yeah photo bucket and what make are your gauges? cheap ones tend to be shit and will only give you a rough idea although they will be better than the stock ones. Peter Quote
