remove p/s pump and try to shoehorn a charger in there, should work with standard 4efe, much like the vw g40, they are massively tuneable, but the 4efe is nearly there and can handle a bolt on turbo kit with great gains so my q is will a charger offer the same(not the same in boost terms as turbo) but is it still a viable option, eaton m45 for example?
Andy
:thumbsup:
Theres pictures of a red one floating about with one fella.
Done just how you said, removed the ps pump and mounted it above the manifold, no one seems to know anything about it though
