Neo95 Posted November 21, 2013 Posted November 21, 2013 Just a quick one. What is the best gearbox oil to put in my EP91 LSD box. Make and weight? Thanks. Quote
oilman Posted November 21, 2013 Posted November 21, 2013 Is it a standard factory fitted LSD or an aftermarket one? Cheers Tim Quote
Neo95 Posted November 21, 2013 Author Posted November 21, 2013 Is it a standard factory fitted LSD or an aftermarket one? CheersTimFactory fitted pal Quote
oilman Posted November 21, 2013 Posted November 21, 2013 Hi I would go for something like Motul Gear 300, Millers CRX 75w-90 or Gulf Competition. http://www.opieoils.co.uk/c-673-75w-90-gear-oils.aspx You don't need the LSD versions of those oils, just the normal versions will do. Cheers Tim Quote
Neo95 Posted November 21, 2013 Author Posted November 21, 2013 Thanks a lot for you help pal. Hi I would go for something like Motul Gear 300, Millers CRX 75w-90 or Gulf Competition. http://www.opieoils.co.uk/c-673-75w-90-gear-oils.aspx You don't need the LSD versions of those oils, just the normal versions will do.CheersTimAnother quick one. How much will it take? Quote
oilman Posted November 21, 2013 Posted November 21, 2013 I'm not 100% sure, I think it's about 2.5L. Cheers Tim Quote
Neo95 Posted November 21, 2013 Author Posted November 21, 2013 I'm not 100% sure, I think it's about 2.5L. CheersTimNice one pal thanks a lot. Quote
