Hi all. I bought some second hand shafts. I tapped the shaft in gently. Baring in mind the car is jacked up really high 1 way to stop oil from comming out it some how pushed the other shaft back a little & started leaking. So I pushed it back in & it stoped is this normal.
I checked that the shaft was exactly the same length etc
Any help would be appreciated
Many thanks mosley
The circlip on the end of the shaft might not have properly engaged, so when you tipped it over it might have just slide loose. Did you replace the axle shaft seals in the gearbox? If they're old and you swap shafts then they don't always seal up again.
Yes mate it is a top fill that's what I was thinking bud lol. Now I pushed it back in to stop seeping do you think it will be ok or shall I take it out just to make sure.
Cheers
