Hi all,
My radio doesn't seem to wanna play ball. It's basically switching on and off when you press the on button. It does take a few presses of the button to make it turn on but when it does, it does the above. I did by pass the 12v wire which is the one for when the car is running and it worked but I couldn't find a ignition live to use without that circuit being affected. Any ideas? It worked fine until one day it started. I checked fuses, wires and changed the unitt
