Ive recently bought a glanza v 1996 , and im having problems with first and second gear, 1st is hard to get into gear but goes in eventually and if i dont change into second slowly, it crunches in to gear... so i went to a garage to have it looked at and they said it will most likely be the gearbox linkage bush thats gone so i need to locate a new one . they said they couldnt get one because the car is an import. so ive been trying to find the correct one.
So has anyone had this problem before that can assist in finding a gear box linkage bush online?? Would be very much appreciated!
Alright, ill go back to the garage and confirm that thats the part i need , then ill go from there. ill let you no what happens :thumbsup: thanks!
