I have a omp deep dish wheel fitted and the horn was only working when you turned the wheel to the right? I popped off the button on wheel and checked the contact all seemed fine but now it's not working at all? Anyone know how to sort it so it works all the time?
Get a volt meter and see if your getting a voltage first. If you are you know its an earthing problem. I.e. Means the horn button isnt earthing the voltage for it to work when your pressing it. Work on from there bud
Thats wierd. Its proberly shorting out if u dont turn the wheel to thr right. Check the wiring coming from power. I recon its shorting out if u dont turn it to the right. Do u know what i mean
Im not sure where its getting power from. But ull have to trace the wire back. Never had a problem like this on my car. My friends skyline had the same problem
