Alight folks I recently bought a glanza with the engine in the boot so built it all up etc but I had no gears clutch bled serveral times but still couldn't selected a gear so what I done was Jamed a nut between the clutch fork and the slave cylinder to push the fork more now I'm getting gears but there tight due to the bite being so low
So would you say the pressure plate or bearing fucked
Or
Would you think the slaves being lazy
Cheers scott
All seem tight mate I'll double check but can't see and leaks and with the peddle to the floor it's not dropping back with the peddle held down
You may not see the leak if it's tiny, just nip the 10mm nuts up to see if it helps. That's where I would start before replacing parts. :)
