Hi can anyone help me I have a ep82 4e need to no what fuel to aim for on my map as over fueling ATM I have td05 k6 emerald ecu bigger injectors 5.5 or 5.9 can anyone help
In terms of A/F ratio somewhere around 11.5-12.0 but depends on the boost pressure, intake temps, coolant temps, air density, knock levels etc.
A map is represented in injector opening time in milliseconds (ms) so you'll just have to adjust it accordingly until you get the desired air/fuel ratio.
