Zeldoz Posted February 12, 2014 Posted February 12, 2014 Take the bottom rad hose off the engine on the right, unbolt the housing and take it out, replace and work backwords! Voila! Quote
dangeestarlet Posted February 12, 2014 Posted February 12, 2014 Take bottom hose off the side of thermostat (just below distributor) and then unplug one sensor so you don't damage it then undo 2 10mm bolts (found it easier with a little spanner ) then pull the case off them swap thermostats over and put all back together. , take note of which was thermostat was but if you got instructions with thermostat it will tell you which way to put it in, it's simple should take ten mins Take the bottom rad hose off the engine on the right, unbolt the housing and take it out, replace and work backwords! Voila! beat me to it haha Quote
mm2101 Posted February 12, 2014 Author Posted February 12, 2014 do you need to tackle it from underneath? no new gasket needed? Quote
Zeldoz Posted February 12, 2014 Posted February 12, 2014 Can do it from above. If it has a gasket i would change it Quote
dangeestarlet Posted February 12, 2014 Posted February 12, 2014 You don't need a gasket, the thermostat rubber seals it, don't take the whole housing off just the bit were the bottom rad hose goes to You don't need a gasket, the thermostat rubber seals it, don't take the whole housing off just the bit were the bottom rad hose goes to Quote
mm2101 Posted February 12, 2014 Author Posted February 12, 2014 so definitely no gasket? will all the coolant run out if when i take off the hose? Quote
Zeldoz Posted February 12, 2014 Posted February 12, 2014 so definitely no gasket? will all the coolant run out if when i take off the hose? It will drop some water, either do it and just re-top your coolant. Or drain it all first, do the job then re-top it up!Ive done it before on my civic, i just did it all whilst it was pouring out. Not too hard but you can do it anyway! Quote
dangeestarlet Posted February 12, 2014 Posted February 12, 2014 Definitely no gasket , the thermostat comes with a rubber ring, just take the hose off and all the water will come out and if I was you when the thermostat is out put a hose pipe in the radiator and flush it all out and then put all back together and re fill with fresh coolant /) Quote
mm2101 Posted February 12, 2014 Author Posted February 12, 2014 right is there a cap where i put fluid directly into the radiator? i really dont have a clue haha Quote
dangeestarlet Posted February 12, 2014 Posted February 12, 2014 Yes fill the radiator cap with coolant and water , start the car for till the fan kicks in with rad cap off then turn it off and leave it to cool and then top up if necessary Quote
Zeldoz Posted February 12, 2014 Posted February 12, 2014 ok thanks for the help lads! We all start somewhere bud! Quote
