TD04HYBRID Posted February 13, 2014 Posted February 13, 2014 Been doing loads of work on the starlet over the last 2 weeks and have had it started since the work been done.However today I disconnected the fuel pump connecter on top to test for the live feed! (Some starlets fuel pump don't purge until crank) and mines one of them. So cranked the engine over with te connecter off several times and the battery seem to be giving up so stopped!Put the connecter back on key in ignition all lights came on dash but wouldn't start battery seemed dead so jumped started it and started fine.Left it running for a good half an hour turned it off went to switch back on but had no power and also won't jump start either!Any ideas? As battery is only 4 weeks old? And thought that it would still jump start even if battery was fucked Starting to lose hope with this Quote
TD04HYBRID Posted February 13, 2014 Author Posted February 13, 2014 Yeah but some times the alarm flickers but then nothing! I'll take the two main fuses out and test continuity to check there fine! If there not where can I purchase them from? Quote
