I need some help in replacing the AT stick without preferably dismantling the whole dashboard :)
Basically I managed to unscrew the two screws at the top of the stick and when I try to pull up the top of the lever, it gets stuck by a wire. That's my first challenge.
The second challenge is to get to the base to be able to put the gear boot inside. So I removed the two clips from the bottom of the center console but looks like I still need to remove the top part of the console (where there is the ashtray, radio, etc). Is this so? If yes, how can I remove it?
Thanks!
