Clutch slave cylinder problems..
Hi all I've been putting my car back together to find that I'm having a problem when trying to bolt my slave cylinder on my gearbox. The problem seems to be that the clutch fork doesn't move enough to allow me to move the slave cylinder in place so I can bolt it to to my gearbox. Not sure what else I can do to try and fit it. Anyone have any ideas that would be great. Hopefully I won't have to remove the gearbox as I don't have the time or the motivation to be removing it...
Just take the pipe off the slave cylinder and undo bleed nipple and push it right in, I had the same problem and just bleed the clutch again
Ive removed the pipe of the slave cylinder and undone the bleed nipple to allow all the fluid out.. I will have another go at it today
