the other goes onto your PCV valve ontop of your rocker cover (you will need to gut the PCV valve so you can blow through it both ways. You will need to block off the other end which goes into the intake manifold. Just ensure your catch can vents to atomsphere though, you dont want to have a closed loop so the air cannot escape.
Edited by Taggy
yes just pull it out, its only held in with a rubber grommit, give it a tug and it should slide right out, just be careful if its old they can go brittle.
