Manny Posted February 25, 2014 Posted February 25, 2014 (edited) Hi guys is the starlet cd model dials instrument cluster with rpm clock plug n go for the other models what don't have the rpm counter? plug n go like no swopping of wires?Any advice Will be appreciated Edited February 25, 2014 by manny Quote
Manny Posted February 25, 2014 Author Posted February 25, 2014 is this true? I've read it somewhere in a blog or guide. anyone confirm it works? Quote
Manny Posted February 27, 2014 Author Posted February 27, 2014 yes they do work I installed cd model cluster with rev counter. you need a lot of patience and thin hands. boy it is tricky and awkward I didn't remove the steering wheel had to juggle the binnacle cover out then removing the speed cable from under foot well area you have to go at arms length and judge n feel where it is to pull it off, then you juggle to clock out and then its reverse process. but its worth it. Quote
Dmoss468-jdm Posted March 23, 2014 Posted March 23, 2014 I need help on this is there any wire swapping ? Quote
