Using the ecu pin out diagram for 4efte ep91 on tgtt im trying to pin point all the necessary sensors from the ecu to wire in my apexi avc-r.
I need to find the following
(Engine RPM) 4- NE Integrated Ignition Assembly (RPM)
(Speed signal) 11- SPD Speed Signal
(Throttle signal) 11 - VTA/PSW Throttle Position Sensor
_____________ Or 12 - VCC Throttle Position Sensor (PIN1)
_____________ Or 13 - IDL Throttle Position Sensor (Signals ECU Throttle Position is at Idle.
Also I Could Pick up the -
(Injector signal) But all I could see was the 2 injector pulse signals for 12 - 10 Injector pulse 1 & 3
_______________ or 25 - 20 Injector pulse 2 & 4
Has anyone wired one of these units before and could point me in the right direction of which wires/sensors to pick up using the diagram.
Thanks,
James.
