From what i read they should. But you Will have to swop wires most likely.
Edited by Manny
Which wires because my car has a rev clock anyway
  • 2 weeks later...
hope this helps, copied from another forum.
I have just fitted some glanza clocks into my SR. There is a pin out for doing this but it does not cover all 3 dash/wiring types I got part way into swapping the wires over and realized my wiring was not the same as the pin out! so after quit a bit of head scratching I came up with a really easy answer! remove the speedo and the rev counter from the glanza housing, remove them from the SR clocks and fit the glanza clocks to the SR housing job done!! every thing works as it should and there is NO wires to change! just plug in the speedo cable and wires and every thing works! but you will still need a speedo converter tho I am using indiglo dials with the 180 MPH face but it will work the same with the standard glanza dials too.
hope this is some use to some one it sure made the job a lot easier for me
