is there anyone out there who could help m with reprogramming key fob for central locking. for a toyota glanza v turbo.
Thanks In Advance.
is it a after market key fob or toyota?
toyota factory fitted
Try toyota mate,if not try your local auto electrics they should be able to help
whats wrong with the fob?
nothing its brand new from toyota there like to sell you the items but wont give you the program to program to the car.
Check with the toyota dealer that you bought of,ask for the foreman or master tech,if they sell them there bound to hav the program mate
With sum cars all you have to do is put the key in the ignition set to the 2nd bit and hold the button on the key shooed work?
Copied this guide from the Paseo club, might be of some use, not sure though:
1. Find the alarm ecu, located behind glove box, cable tied under dashboard to the left (not the engine ecu you see directly in front of you!).
2. Remove cable ties carefully allowing access to unit.
3. You will see a bracket on the unit that is held on with a screw at one point and a rivet at the other.
4. Remove the screw allowing the bracket to move on the axis of the rivet.
5. You will see a small green coloured button.
6. Turn ignition to 'acc'.
7. Use a small pin, needle or similar to press the green button till you hear it physically click in.
8. Press and hold both buttons on the remote fob for several seconds until you hear the alarm ecu 'click'.
9. Your new key fob should be now coded to the vehicle, test then replace alarm ecu with new cable ties.
10. Sit back and relax, reflecting how you saved yourself a fortune for 10 minutes work
