Jap91 Posted April 8, 2014 Posted April 8, 2014 As above lads..Need to check if an injector is overfueling as i cant get passed the emissions test?Whats the best way to test them? Quote
yaristurbo Posted April 8, 2014 Posted April 8, 2014 were the emissions showing a overfueling state? do you have a print out? Quote
Jap91 Posted April 8, 2014 Author Posted April 8, 2014 Have a print out.. Checkd plugs earlier,center two plugs wer wetish,outer two wer dry!So i swapd the injectors,outer two to inner two and il check tmro if the outer two are wet..Has very high readings on low and hi idle.. Quote
mech5107 Posted April 8, 2014 Posted April 8, 2014 Maybe clogged or something. Get all the injectors ultra sonic tested and cleaned Quote
