Vicep82 Posted April 16, 2014 Posted April 16, 2014 As the title above No idea what it is Any help would be helpfull cheers Quote
Taggy Posted April 16, 2014 Posted April 16, 2014 Either the knock sensor has failed which is the plug on the back of the engine, or the wiring has failed. You need to test the continuity with a multimeter on the plug end to the ECU plug wire for the knock sensor, if thats ok then replace the knock sensor. It will run rough as a bag of spanners until you fix above as the car is running in a safety mode. Quote
