Ive Recently Serviced my Engine, New Oil, Plugs, Oil Filter, Air Filter. So now i want to change timing belt and water pump,
I'm Just Wondering does the regular Toyota Starlet Non Turbo 1.3 96-99 timing belt and water pump fit the 4EFTE Glanza V?
Only if you've removed the aircon as that belt is shorter. Not sure about the water pump.
  • 2 weeks later...
This information is wrong...whether you remove the air con pump or not it has nothing to do with the timing belt. check out toyodiy.com and you can then cross reference part numbers to see if the timing belt and water pump part numbers are the same between turbo and n/a models
My bad, for some reason I was thinking power steering belt.
