Looking to go 300bhp with td04 hybrid whats best injectors to use that wont be under to much strain, ive been told 550cc are to big? Any ideas
Regards Albert
What management are you going to be using is probably the most important factor. 550's will be fine and will keep the fuel pressure fairly low.
You'll ideally need a minimum injector size of 466cc/min to get 300bhp safely with a max duty cycle of 90%, you could go higher on the duty cycle upto like 95% but that's down to how comfortable your tuner is with running that sort of figure.
I think 550 are cool. I saw a set of 550s from a 3sgte going for £10 on ebay.
Heres the item number 201073924382
Just to be sure check up if they are 550 cc
Edited by Turk
